Drunlar
Newbie level 2
I have been trying to figure out how to wire a rotary switch in my car and "call me thick" I am having a tough time figuring this out. I wondered if anyone has any tip or help could help me out.
What I need to perform...
I have 4 connections/positions:
1) An empty position lack of connections on other positions (that should be easy just don't add wires to that selection setting).
2) A normally open positive to positive connection that should be closed when position 2 is selected.
3) A normally open negative to negative connection that should be closed when position 3 is selected.
4) A normally closed positive to positive connection that should be closed when position 4 is selected.
NOTE: If 4 is too complicated that is an option, I consider would be nice to have but not absolutely necessary.
After researching this stuff I was thinking perhaps a "3 pole 4 way" rotary switch would fit my needs but can't figure out the details on that. At this point I was considering perhaps just getting a "3 pole 4 way rotary switch" and just playing with it to see if I could make it do what I wanted.
So if anyone has any advice for me on what I need, how to wire it, where to get the supplies I need, just about any information you would consider helpful, I would be very grateful.
