imranahmed
Advanced Member level 3
- Joined
- Dec 4, 2011
- Messages
- 817
- Helped
- 3
- Reputation
- 6
- Reaction score
- 3
- Trophy points
- 1,298
- Location
- Karachi,Pakistan
- Activity points
- 6,492
Please let me know that I want to interface rotary encoder with arduino
but I tried some programs but when I rotate encoder then some readings are missed
#include <Arduino.h>
// constants
const int PinCLK = 2; // Used for generating interrupts using CLK signal
const int PinDT = 3; // Used for reading DT signal
const int PinSW = 4; // Used for the push button switch
// global vars
volatile int virtualPosition = 0;
// forward decls
void isr();
void loop();
void setup();
// Interrupt service routine is executed when a HIGH to LOW transition is detected on CLK
void isr () {
if (!digitalRead(PinDT))
virtualPosition = virtualPosition + 1;
else
virtualPosition = virtualPosition - 1;
} // isr
void setup() {
Serial.begin(9600);
pinMode(PinCLK,INPUT);
pinMode(PinDT, INPUT);
pinMode(PinSW, INPUT);
attachInterrupt(0, isr, FALLING); // interrupt 0 is always connected to pin 2 on Arduino UNO
Serial.println("Start");
} // setup
void loop() {
int lastCount = 0;
while (true) {
if (!(digitalRead(PinSW))) { // check if pushbutton is pressed
virtualPosition = 0; // if YES, then reset counter to ZERO
while (!digitalRead(PinSW)) {} // wait til switch is released
delay(10); // debounce
Serial.println("Reset"); // Using the word RESET instead of COUNT here to find out a buggy encoder
if (virtualPosition != lastCount) {
lastCount = virtualPosition;
Serial.print("Count=");
Serial.println(lastCount);
} // while
} //loop
