xpress_embedo
Hello!! Everyone i am using this rotary encoder
https://in.element14.com/bourns/3315c-001-016l/encoder-16cycles/dp/9354026?Ntt=9354026
But it is not working properly
I am using PIC18F27j53 Micro-Controller
My RC6 pin is connected to Channel A and RC7 to Channel-B
Here is my Code, please help me what to do
On oscilloscope pulses are perfect,
Both lines are pulled up by 10k resistor
Please help.
Waiting for reply
Code C - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 /* Programmer :- Arun Sharma Audio Controller Firmware for PIC18F27j53 Micro-Controller Firmware Version -> v0.0 This version includes basic start up of project from roots. First phase of development process */ #include <p18F27J53.h> #include <delays.h> /******************CONFIGURATION BITS****************/ #pragma config WDTEN = OFF //WDT disabled (enabled by SWDTEN bit) #pragma config PLLDIV = 5 //Divide by 5 (20 MHz oscillator input) #pragma config STVREN = ON //stack overflow/underflow reset enabled #pragma config XINST = OFF //Extended instruction set disabled #pragma config CPUDIV = OSC1 //No CPU system clock divide #pragma config CP0 = OFF //Program memory is not code-protected #pragma config OSC = HSPLL //HS oscillator, PLL enabled, HSPLL used by USB #pragma config FCMEN = OFF //Fail-Safe Clock Monitor disabled #pragma config IESO = OFF //Two-Speed Start-up disabled #pragma config WDTPS = 32768 //1:32768 #pragma config DSWDTOSC = INTOSCREF //DSWDT uses INTOSC/INTRC as clock #pragma config RTCOSC = T1OSCREF //RTCC uses T1OSC/T1CKI as clock #pragma config DSBOREN = OFF //Zero-Power BOR disabled in Deep Sleep #pragma config DSWDTEN = OFF //Disabled #pragma config DSWDTPS = 8192 //1:8,192 (8.5 seconds) #pragma config IOL1WAY = OFF //IOLOCK bit can be set and cleared #pragma config MSSP7B_EN = MSK7 //7 Bit address masking #pragma config WPFP = PAGE_1 //Write Protect Program Flash Page 0 #pragma config WPEND = PAGE_0 //Start protection at page 0 #pragma config WPCFG = OFF //Write/Erase last page protect Disabled #pragma config WPDIS = OFF //WPFP[5:0], WPEND, and WPCFG bits ignored #pragma config CFGPLLEN = OFF /****************************************************/ /****************PIN DETAILS****************/ #define LCD_RS LATAbits.LATA2 #define LCD_EN LATAbits.LATA3 #define LCD_DATA LATB #define LCD_CLEAR 0x01 #define LCD_CURSOR_OFF 0x06 #define FIRST_ROW 0x80 #define SECOND_ROW 0xC0 #define ENCODER_A PORTCbits.RC6 #define ENCODER_B PORTCbits.RC7 /********************************************/ /******************Function Prototypes*****************/ void Delay_ms(unsigned int time); void Lcd4_Init(void); void Lcd4_Cmd(unsigned char value); void Lcd4_Write(unsigned char value); void Lcd4_Write_Text(unsigned char msg[]); unsigned char * CopyConstToRAM(unsigned char *dest, const rom unsigned char * src); void Clear_Destination_Buffer(void); void HIGH_ISR(void); void LOW_ISR(void); /***********************************************/ const rom unsigned char text[] = "ESSEL SHYAM!"; const rom unsigned char love[] = "PIC"; unsigned char ram_msg[16]; unsigned char character[] = {0,10,21,17,17,10,4,0}; unsigned int count = 0; unsigned char flag = 0; unsigned char time_A = 0, time_B = 0; /******************ISR CODE*********************/ #pragma code high_vector = 0x08 void interrupt_at_high_vector(void) { _asm GOTO HIGH_ISR _endasm } #pragma code #pragma interrupt HIGH_ISR void HIGH_ISR(void) { if(INTCON3bits.INT1E & INTCON3bits.INT1IF) { if(ENCODER_B == 1) { if(count <= 999) count++; flag = 1; } else if(ENCODER_B == 0) { if(count > 0) count--; flag = 1; } //while(ENCODER_A == 0); //Stay Here INTCON3bits.INT1F = 0; } } void main() { unsigned char i; unsigned char ones,tens,hundreds; unsigned int temp; EECON2 = 0x55; EECON2 = 0xAA; PPSCONbits.IOLOCK = 0; //Allow Remapping RPINR1 = 0x11; //RP17 as External_Interrupt Pin EECON2 = 0x55; EECON2 = 0xAA; PPSCONbits.IOLOCK = 1; Lcd4_Init(); Lcd4_Cmd(LCD_CLEAR); Lcd4_Cmd(LCD_CURSOR_OFF); Lcd4_Cmd(LCD_CLEAR); CopyConstToRAM(ram_msg,text); Lcd4_Write_Text(ram_msg); Delay_ms(10); //Store Heart in CGRAM of LCD Lcd4_Cmd(64); for (i=0;i<=7;i++) { Lcd4_Write(character[i]); } Lcd4_Cmd(SECOND_ROW); Lcd4_Write('I'); Lcd4_Write(' '); Lcd4_Write(0); //Custom Character Lcd4_Write(' '); CopyConstToRAM(ram_msg,love); Lcd4_Write_Text(ram_msg); TRISCbits.TRISC6 = 1; //Rotary Encoder_A as Input TRISCbits.TRISC7 = 1; //Rotary Encoder_B as Input //Enable Interrupts INTCON3bits.INT1E = 1; INTCON3bits.INT1IP = 1; //High Priority INTCON2bits.INTEDG1 = 0; //Interrupt on Falling Edge INTCON3bits.INT1F = 0; INTCONbits.PEIE = 1; INTCONbits.GIE = 1; INTCON3bits.INT1F = 0; while(1) { if(flag != 0) { Lcd4_Cmd(LCD_CLEAR); temp = count; ones = temp%10; temp = temp/10; tens = temp%10; temp = temp/10; hundreds = temp%10; Lcd4_Write(hundreds | 0x30); Lcd4_Write(tens | 0x30); Lcd4_Write(ones | 0x30); flag = 0; } } } /**************Function Definitions*************/ void Delay_ms(unsigned int time) { unsigned int first; unsigned int second; for(first=0;first<time;first++) { for(second=0;second<650;second++) { Delay1TCY(); } } } void Lcd4_Cmd(unsigned char value) { LCD_RS = 0; LCD_DATA = ((value>>4) & 0x0F); LCD_EN = 1; Delay_ms(1); LCD_EN = 0; LCD_DATA = (value & 0x0F); LCD_EN = 1; Delay_ms(1); LCD_EN = 0; Delay_ms(1); } void Lcd4_Write(unsigned char value) { LCD_RS = 1; LCD_DATA = ((value>>4) & 0x0F); LCD_EN = 1; Delay_ms(1); LCD_EN = 0; LCD_DATA = (value & 0x0F); LCD_EN = 1; Delay_ms(1); LCD_EN = 0; Delay_ms(1); } void Lcd4_Write_Text(unsigned char msg[]) { while(*msg) { Lcd4_Write(*msg); msg++; } } void Lcd4_Init(void) { TRISB = 0x00; TRISAbits.TRISA2 = 0; TRISAbits.TRISA3 = 0; LCD_RS = 0; //Command Register LCD_EN = 0; LCD_DATA = 0x03; LCD_EN = 1; Delay_ms(1); LCD_EN = 0; Delay_ms(1); LCD_EN = 1; Delay_ms(1); LCD_EN = 0; Delay_ms(1); LCD_EN = 1; Delay_ms(1); LCD_EN = 0; Delay_ms(1); Delay_ms(1); LCD_DATA = 0x02; // Four bit mode LCD_EN = 1; Delay_ms(1); LCD_EN = 0; Delay_ms(1); Lcd4_Cmd(0x28); Lcd4_Cmd(0x0C); Lcd4_Cmd(0x01); Lcd4_Cmd(0x06); } unsigned char * CopyConstToRAM(unsigned char *dest, const rom unsigned char * src) { Clear_Destination_Buffer(); for(;*dest++ = *src++;) ; return dest; } void Clear_Destination_Buffer() { unsigned char i; for(i=0;i<16;i++) { ram_msg[i] = 0; } } /***********************************************/
Please help.
Waiting for reply
