role of the pad in SIM 508
yassin.kraouch
Advanced Member level 2
SIM 508 Pads
Can anyone help me to know the role of the pad in SIM 508 as shown in the picture??
regards,
SIM 508 Pads
Those are the mounting tabs that hold the module to your PCB. You should have a hole in your PCB at each of the 4 locations, and then use a nut & bolt to fasten the module to the PC.
Re: SIM 508 Pads
ok thank you GSM man i think that it has relation with the ground or power
Re: SIM 508 Pads
but on the datasheet it is not mentionned that this pad should be grounded
