Re: Robust 50dB Image Rejection Ratio without any calibratio
Describe what you want to do in more detail.
What type of receiver? I+Q or normal? Double or single conversion?
What do you mean by "several MHz"? To me that means 2-5MHz
PVT is "process, voltage and temperature". Are you designing an IC?
When you say "without calibration" do you mean without alignment at the factory when the receiver is made?
In a normal receiver the bandpass fitlering in the front end of the receiver sets the image rejection ratio. If your first intermediate frequency is 5MHz you need the 2GHz filter on the input of your receiver to attenuate signals at either 1990MHZ or 2010MHz (depending on LO frequency) by 50dB. It is hard to make a filter that narrow and impossible without testing and alignment at some stage. You might be able to buy a filter module that has been ajdusted by the manufacturer.
Let me refine my quesiton.
1. I adopt the Image rejection architecture rather than the preceded filter to
reject the image.
2. The conversion should be single conversion from RF to IF. And, do the image
rejection in the IF.
3. Any integrated image rejection method is welcome, such as polyphase filter,
complex filtering, dobule quadurate..etc
4. PVT is Process, Voltage, Temp variation.
