Jan 26, 2008 #1 M mnoman Newbie level 5 Joined Feb 26, 2006 Messages 8 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,353 rj11 to db9 I have to connect my PC's serial port to a console port of an other equipment such as a router or any txn equipment.
Jan 26, 2008 #2 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,407 Helped 14,749 Reputation 29,780 Reaction score 14,095 Trophy points 1,393 Location Bochum, Germany Activity points 298,039 rj11 db9 Hello, there is no standard for RJ45 RS232 pin mapping, it's propietary to manufacturers. It should always be documented with the respective user manuals, also many manufacturers supply an adapter. This is e. g. the pin mapping I found with a Cisco router: Adapter Cisco RJ45-DB9 1 n.c. <- 7 RTS bn 2 DTR <- 4 DTR bn/wh 3 TxD <- 3 TxD gn 4 GND 5 GND bl/wh 5 GND 5 GND bl 6 RxD -> 2 RxD gn/wh 7 DSR -> 6 DSR or 8 n.c. -> 8 CTS or/wh Regards, Frank
Jan 4, 2009 #3 S stratcat50 Newbie level 5 Joined Jan 3, 2009 Messages 9 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,324 db9 to rj11 https://yost.com/computers/RJ45-serial/ has good info
