I allready encountered that ground bounce phenomenon, after powerup the onchip ground jumps to about -800mV and needs about 50ns to stabilize at 0V.
I used 100ps as rise time, I think this will be realistic for signals coming from an 1GHz Labview PXI digital measurement system.
So if this is the normal behaviour, how is it normaly solved? Adding that gate resistor (is there a recommended size?)? Or is there a better option? Sadly there are no courses on digital chip design at my university, I am working with the analog circuit design department and the know how on digital integrated circuits is very limited.
Thank you a lot!
