of course u can use a ring oscilator with 1v supply. u ca search in IEEE to try to find some papers about this issue.
The minimu length in 90nm should be 90nm
If you are designing for max Ft, you must use min length, otherwise what is the benifit of using smaller feature size anway,
long channel devices are typically used for bias circuitry when you dont need high frequency operation
