nikhil@avench
Newbie level 1
hi,
I am using RR version DM355SDK701905 which is the only available version now. and dvsdk 2_00_00_22 and Ubuntu 11.04.
1 while giving make VERBOSE=1 i am getting the following error. Please help me to fix this error..
Thank you..
mv dvsdk_2_00_00_18/Rules.make dvsdk_2_00_00_18/Rules.make.orig
echo PLATFORM=dm355 > dvsdk_2_00_00_18/Rules.make
cat Rules.make >> dvsdk_2_00_00_18/Rules.make
quilt push -a
Applying patch dvsdk.patch
patching file dvsdk_2_00_00_18/dsplink-1_60-prebuilt/packages/dsplink/make/Linux/davinci_mvlpro5.0.mk
7 out of 7 hunks FAILED -- rejects in file dvsdk_2_00_00_18/dsplink-1_60-prebuilt/packages/dsplink/make/Linux/davinci_mvlpro5.0.mk
patching file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm6446/decode/Makefile
3 out of 3 hunks FAILED -- rejects in file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm6446/decode/Makefile
patching file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm6446/encode/Makefile
3 out of 3 hunks FAILED -- rejects in file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm6446/encode/Makefile
patching file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm6446/encodedecode/Makefile
3 out of 3 hunks FAILED -- rejects in file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm6446/encodedecode/Makefile
patching file dvsdk_2_00_00_18/examples/dm355/jpegdec/Makefile
patching file dvsdk_2_00_00_18/examples/dm355/jpegenc/Makefile
patching file dvsdk_2_00_00_18/examples/dm355/vdec/Makefile
patching file dvsdk_2_00_00_18/examples/dm355/venc/Makefile
patching file dvsdk_2_00_00_18/dmai_1_20_00_06/packages/ti/sdo/dmai/Makefile
patching file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm355/decode/Makefile
Hunk #1 FAILED at 13.
Hunk #2 FAILED at 39.
Hunk #3 FAILED at 82.
3 out of 3 hunks FAILED -- rejects in file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm355/decode/Makefile
patching file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm355/encode/Makefile
3 out of 3 hunks FAILED -- rejects in file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm355/encode/Makefile
patching file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm355/encodedecode/Makefile
3 out of 3 hunks FAILED -- rejects in file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm355/encodedecode/Makefile
patching file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm355/interface/Makefile
Hunk #3 FAILED at 81.
3 out of 3 hunks FAILED -- rejects in file dvsdk_2_00_00_18/dvsdk_demos_2_00_00_04/dm355/interface/Makefile
patching file dvsdk_2_00_00_18/dmai_1_20_00_06/packages/ti/sdo/dmai/apps/Makefile.app
patching file dvsdk_2_00_00_18/dvtb_4_00_04/packages/ti/sdo/dvtb/dm355/Makefile
Hunk #1 FAILED at 29.
1 out of 1 hunk FAILED -- rejects in file dvsdk_2_00_00_18/dvtb_4_00_04/packages/ti/sdo/dvtb/dm355/Makefile
Patch dvsdk.patch does not apply (enforce with -f)
make[3]: *** [patched] Error 1
make[3]: Leaving directory `/opt/DM355SDK701905/proprietary/dvsdk_2_00_00'
Error building dvsdk_2_00_00
make[2]: *** [dependency_build] Error 1
make[2]: Leaving directory `/opt/DM355SDK701905/proprietary'
make[1]: *** [proprietary_src_build] Error 1
make[1]: Leaving directory `/opt/DM355SDK701905/fs'
make: *** [fs_build] Error 2
Thank you..
quilt push -a
