elvis0206
Junior Member level 1
Hi friends,
I recently want to design a RFID tag antenna with working range about 10-15cm. The power supply is 3.7V to 3.8V.
I had designed a rectangular antenna with round corner, however, the working range was about 5cm which is to small to work. Therefore, I want to design an new antenna with another pattern in order to achieve the maximum working range with the same power supply stated before. Does anyone have some good ideas???
