DeanM
Newbie level 3
Hi all,
Been reading the board for a while now but this is my first post. Lot of useful information and very knowledgable people here!
My first post is seeking help! I'm working on an RFID project. It uses the u2270B basestation and a TK5551 tag for testing. The schematic is the same pretty much as application 1 in the u2270B data sheet. For the antenna i'm using these...(link below) they are 700µH coils but i use two in series for 1.4mH.
RF SOLUTIONS|ANT-125K|ANTENNA, COIL, RFID, 125KHZ | Farnell Ireland
I used a 100Ω pot for R thinking it might allow me to tune it better.
I'm getting roughly126KHz square wave output from the coil outputs. This is generating an almost sinusoidal waveform before the diode in the demod section.
PROBLEM: As mentioned, i'm getting a 126KHz waveform. after the diode i am only getting a DC voltage of about 12V. I know the RF wave should be demodulated and the input pin should show a rectified version of whats shown in the e5551 data sheet. One side of the inputcap is around 12VDC and the u2270 side of the input cap is about 2.5VDC. The cap shouldn't be passing DC. i'v changed caps a couple times and same thing is happening.
also, I seem to be getting data on the OUTPUT pin even when there is no RFID tag near the antenna.
I thought maybe the chip is damaged but its producing the output wave so i'm not certain. any thoughts? Any input would be very much appreciated. i can post schematic and PCB layout if needed.
Regards,
DeanM
Regards,
DeanM
