I'm looking for a circuit that is called "RF clamp", "RF limiter", "voltage clamp" or "voltage limiter".
The example of such circuit is a transistor Q on this picture:
However, what I need is a full RF clamp circuit. Not only the transistor shown in the example above. The gate bias of this transistor would be very useful.
I cannot find many of such circuits. Often, they are stacked diodes on antenna lines or diodes + resistor to bias transistor clamp.
Do you know where I could find good examples? Any books, websites?
A series of shottky diodes in two back to back strings should do it. We used 7+7 (from memory) to protect from 1W, good to 30 MHZ. The secret is to use a ferrite input and output transformer. The DC current saturates the cores giving lower coupling.
Frank
To get the best circuit efficiency the clamping diodes should be placed outside of the chip. I remember while ago, we were in a situation when the internal CMOS clamping circuit fails very often, due to a poor chip layout design.
