Tricka90
Member level 1
- Joined
- Sep 2, 2013
- Messages
- 40
- Helped
- 1
- Reputation
- 2
- Reaction score
- 1
- Trophy points
- 8
- Activity points
- 385
I built a very simple circuit consisting in a RF transmitter / receiver, a PIC microcontroller, a Fan and a little LED Lamp. Pressing a button on a RF transmitter I can turn on and off the Fan or the Lamp.
The all circuit is powered by a 5V - 3A power supply.
In the link below you can see the RF transmitter / receiver modules:
https://forum.hobbycomponents.com/viewtopic.php?f=25&t=1324
That's how the Lamp is powered (the Fan is powered the exact same way):
The R1 resistor is used to limit the current through the Lamp / Fan.
The circuit does work perfectly! The problem is I can't improve it: I'd like to decrese R1 value both on the Fan and the Lamp so they can work better. The problem is, the more current the two loads absorb, the more dirty and imprecise the receiver output signal becomes! I measured it with my oscilloscope and it's obvious that when I decrese R1 the signal gets a lot of interferences so the PIC can't read it correctly.
I tried connecting some capacitor here and there but it didn't solve anything. It even becomes worse with big capacitor values!
Now the Lamp and Fan absorbs only 200mA each, that's pretty low.
Do you have any solution for letting the Lamp and Fan absorb more current while keeping the receiver output signal as clean as possible?
