trevorth
Newbie level 6
I have a 2.4GHz board with a class 1 bluetooth PA IC (Skyworks) and RF switches to bypass the PA for receive.
I have the prototype but am having the following problems:
1). When in transmit via the PA path, the output is -30dBm.
It should be +25dBm at the output of the PA, thus I expect +20-22dBM at the connector/antenna after the filter/switch.
2). When in transmit not via the TX path (i.e. bypass the PA), the output is -60dBm as though theres nothing there.
I can set the transceiver to 0dBm but just dont seem anything.
When the transciever is outputting 0dBm and the amplifier is on (+20dBm), data (verified by a CRC check) can be received by another module in close proxmity. So it is outputting some valid RF.
The following peaks are observed on the spectrum analyser:
2.33GHz -65dBm
2.40GHz -51dBm (Carrier)
2.44GHz -38dBm
2.48GHz -54dBm
2.54GHz -52dBm
2.59GHz -50dBm
Questions
I have verified the logic to the switches but cannot verify the switch is closed/open as both paths show the same resistance, <3ohm. Ive tried a voltage across the seitch with the same uncertainty. Is there something special about these RF switches which means they only provide isolation at high frequency?
All the traces are very short (<10mm). Can impedance matching along the short paths and at the output really cause so much power loss? And also cause a reflection to have a greater power level as seen on the spectrum anlayzer?
If I can verify the RF switches are operating correctly (which I think they are) the other issue that I can think of is the 12pF capacitors but I did check they would provide little impedance at that frequency.
Regarding a Vector Network Analyser and impedance matching, are there any guides on how to use one to determine antenna matching and where to take measurements from i.e. do I need to make another prototype board with connectors along the path? Is this an aspect thats normally simulated?
Thanks in advance for any guidance.
2.33GHz -65dBm
2.44GHz -38dBm
2.48GHz -54dBm
2.54GHz -52dBm
2.59GHz -50dBm
Questions
