I am designing a power amplifier for between 1.7 and 1.8 GHz. I plan to use the BFG135A power transitor from Infineon. The thing I am interested in is the 1 dB compression point of this device. it is mentioned nowhere in the datasheet and I cant find it anywhere. My input signal power level is 25 dBm and I want 30 dBm out after the amplifier stage. But i want to know if the active device can handle the input power level and still give some gain.
Thanks, do you perhaps know of a power transistor that can handle an input power of more than 25 dBm? I want the device to take 25 dBm comfortably, so i cant really use the BFG135A then. I need some room to allow for signal fluctautions.
I think that your choice of BFG135A transistor as power amp for that levels is not good. Please specify your requirements and VCC /I which you can use in amp than we can suggest you a much better solution maybe:?:.
GL XTASA
Any thoughts on which device will be suitable will be appreciated. This is my first time desiging a power amp so i dont know which devices are really used.
I prefer if it is a BJT. but if it is a FET is will be okay i guess.
