RF Power amplifier stability
Mabrok
Full Member level 4
I have designed class AB Power amplifier for 3.4-3.6 GHz band. When i checked the stability, the amplifier was stable over the entire band (K>1). But for out of band at certain frequencies (0.5 to 1.2 GHz & 3.9 GHz ) is unstable. So, Is this condition will have an effect on the PA's performance?
BigBoss
Advanced Member level 5
Turkey
The amplifier may oscillate-not definitely but-.If K<1, the amplifier is conditionally stable so certain load and source impedances may drift it into oscillation.If K<0, the amplifier will probably oscillate..
Adding resistors at input and/or at output may help you or highpass/lowpass filters can also help to reduce the risk.
Reactions: Mabrok
    Mabrok
Mabrok
Full Member level 4
I have added resistor in series and helped in enhancing the stability. but on the other side degraded the gain too much.
BigBoss
Turkey
Parallel resistors are used at input/output or both..Consider also highpass/lowpass filter combination.
There are numerous solution for the stability..
Reactions: Mabrok
    Mabrok
