Hello,
I am designing a RF PCB with a WiFi module. The trace thickness of the antenna feed is 4.9 mils for 50ohm impedance. This signal width is thin compared to the matching component pads (ie 0402 size) and edge SMA center diameter pads. Many of the layouts I've seen for RF boards define a stackup such that the 50ohm trace width is the same as component pad width.
Is it necessary to define a stackup so that the width is the same for the antenna trace and the SMD components? As long as I maintain 50ohm, would it matter what the trace thickness is compared to component pads?
Thanks
