Rf mole transmission rate
jaycec
Member level 2
india
Hi all
My rf transmitter module has a transmission rate of 3000bits per second.is 3000bits per second is same as a baud rate 3000?if no please specify the baud rate equivalent of 3000bits per second.
Bit rate = Baud rate * Number of bits transmitted per baud.
If your RF module uses FSK (Frequency Shift Keying) modulation, each baud transmits one bit; only one change in state is required to send a bit. So bit rate and baud rate will be the same i.e. 3000 bits/sec.
