Dummyeng
Member level 4
Hi
i design an amp with MRF13750 i put them in parallel (Balance arch)
so
1- i used BLC and i dont put any cap between gates but i have seen in famous company design like EmPower they put some caps between two drains and some caps between two gates specially put trimmer cap between two gates. should i consider this kind of capacitor? or i should follow my design?
2- in load pull and impedance matching i design only for one gate then copy it for another gate is it correct?
3- in datasheet they said that it can only give us 700W but in simulation i could get more than 1KW with almost 45% efficiency so about drain current in simulation show it wants almost 55A is it correct?it is only for one tr and when i parallel them i can get more than 62dBm
4- my board length is more than 60cm (for two) should i use tandem to decrease my size?(any other suggestion)
so
