Hello!
On a PCB I have RF, digital, and analog sections.
RF section has a strong +5 dBm LO feeding the mixer operating in the MHz range.
The analog section consists of an active filter working in the kHz range with much weaker -15 dBm signals.
In PCB practice, power planes (and sometimes ground planes) of the analog and digital sections are usually partitioned and separated.
So my question is: should I separate the RF section from the digital and lower-frequency analog sections as well? Or can the RF section use the same power/gnd planes as the analog?
