Arch Angel
Newbie level 3
Hello..
I am currently working on my FYP which involves two autonomous robots. I have chosen to use two PICs 16F877a and two RF modules 433MHz to automatically start and stop the system.
At the start, one robot is powered and a signal should be sent through the RF which causes the other robot to start automatically.
When the desired distance has been reached, a signal should be from the main robot to the other to stop them.
I am not able to write the appropriate coding for this. I know i need to use manchester code library but im new to it.
Can someone please help me with sample codes?
Thank you very much in advance..
