Applying Miller's theorem always gives you an equivalent circuit.
You never have problems with this circuit if you do not change the excitation source.
If you do change the excitation source then you have to reapply Miller's theorem for the new conditions and you will get a different equivalent circuit.
Just two examples where Miller theorem is used not correctly.
1. You excite the circuit at its input with a source Vs and get an equivalent circuit.
2. You then use this equivalent circuit to find Ro=Vt/It by connecting a
test source Vt to the circuit output and suppressing Vs.
2. You then use this equivalent circuit to find return ratio.
