Rick M
Newbie level 2
Resistor question
I have to drain some caps in my Fender hot rod deluxe tube guitar amplifier in order to replace a faulty input jack. I'm told the caps can retain several hundred volts. Also told the best way to drain them is to place a 25k, 10watt cement resistor between the ends of the cap. I can't find that value resistor at my local radio shack. can I substitute a different value resistor? Radio Shack has several 10 watt versions, but different ohms - as I recall - maybe 100 ohm or 10 ohm. Any suggestion would be much appreciated.
Thanks,
Rick
Thanks,
Rick
