Resistor matching technique in CMOS process
rainman.cn
Member level 2
Member level 2
In cmos process, we have several types res, N+, P+, poly1, M1, M2, and so on,
but which type match better,
regards,
rainman
res match problem
match what?
can you explain what you mean?
res match problem
These several types res can all match well as long as their W and L is big enough.
I only know that variation of res value of different corner is different obviously
Re: res match problem
differet type of resistors has different matching characteristics. it depends on the function.
res match problem
you must find the data from the model munual by the factory
Usualy is matching by poly resistors the best. But look at your technology process specification.
Generally poly res matching is best. It depends on the process you use.
