Resistor inductor on inverter
franticEB
Full Member level 3
Full Member level 3
i've found an old inverter schematic with an inductor and resistor on high mosfets' drain as figure below
I try to reproduce it without RL circuit and mosfets become hot (80° over ambient) for conduction and switching losses as in my calculations.
Then i tried to mount the RL circuit and temperature rise on mosfets was very low (30° over ambient).
I did not understand how this circuit (RL red circle in figure) acts and how you can calculate component values.
Could you help me? I don't found anything (tutorial or application note on this subject).
This RL also allow me to increase switching frequency...
Parameters:
Fswitching=50Khz
Pout=150Wrms
Maybe the RL prevents from high current during cross conducting of two fets.
But i don't know...
Klaus
Hello franticEB,
Z(L) = jwL
For DC circuit, w=0 and so the resistor at the drain is actually shorted. Which is why the there is no power dissipation through the resistor and it stays cooler. Thanks.
LaTeX Commands Quick-Menu:
