Resistive Touch Screen - Driver required?
wind_blast942
Newbie level 3
Hi
I am currently doing a project that requires the use of a touchscreen. The one that I plan to use is this : **broken link removed**
However I am not sure for this kind of touchscreen, do I have to purchase ab additional driver chip to make it work or is it trivial enough to program the pic 16 that I already have? As I have budget constriants, I was hoping that the additional chip is not needed.
Any help is much appreciated thanks.
dr pepper
Advanced Member level 1
lancs
You could program a pic to do that, scan the rows with a logic '1' and measure the analog voltage on the columns for feedback, noise is an issue, you might want to put a decodable pulse train on the rows so you know your feedback isnt just noise.
There are probably commercial chips for doing that, with an output similar to a keyboard. or mouse.
dhaval4987
Full Member level 3
AZ
you can program the controller to do it and can do without additional driver IC. But you will have to caliberate by your self. using driver- you will find much better caliberated results but you will miss the fun of writing a code by yourself to read the touch screen data!
