Gargy
Hello!
I need your help. I want to design a circuit for measuring resistance. The problem is that this device should be accurate from 1Kohm to 1Gohm. Plan is bigger load, better accuracy.So basicly I have two options - fixed voltage and measuring current through load or vice versa - current source and measuring voltage drop on load. Load can be 20m away form the circuit itself.
First option (fixed voltage) - i can use voltage boosters from linear technology which can generate stable 80V DC, but current on high load will be very small and sensing this current (100nA or less) in long cables can be difficult and can produce errors.
Second option (current source) - maybe 1 uA current source, but than I need 1000V voltage source on high loads.
Anybody has an idea? And sorry for my grammar, I'm from Slovenia.
Regrads,
Gargy
Regrads,
Gargy
