Resistors in Integrated Circuit show thermal, shot and fricker noise.I'm also surprised why a resistor would have flicker noise.
I would expect thermal noise only.
It is nominal resistor.So that's different from "normal" resistors?
Even carbon resistor shows fricker noise.In our seminar on RF noise,
we learned that resistors (linear and passive) show purely thermal noise.
Show me noise contribution table.There simulation are different,
I wonder which one is correct,
Makes no sense.sorry, the models are on the server and l can't copy. could you please give me a way to solve this problem? thanks.
Simply I will correct your verilog-a code.sorry, the models are on the server and l can't copy. could you please give me a way to solve this problem? thanks.
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 //////////////////GLOBALFOUNDRIES MODEL//////////////////// module res_flicker_noise(p, n); inout p, n; electrical p, n; parameter real rmain=1e3; parameter real l=0; parameter real w=0; parameter real dw=0; parameter real dl=0; parameter real rsh0=0; //parameter real (* integer inherited_mfactor; *) m = 1; //flicker noise parameters parameter real kf=2.62e-26; parameter real af=2; parameter real lf=1; parameter real wf=1; parameter real ef=1; parameter real m=1; real r_l, r_w; real i_r; real geo; analog begin r_l=l-2*dl; r_w=w-2*dw; // added by Ramkumar //Weff = w - 2*etch; //Leff = l - 2*etchl; //geo = pow(Weff, weexp) * pow(Leff, leexp) * pow(w, wdexp) *pow(l, ldexp); // end i_r=V(p,n)/rmain; geo = pow(r_w, wf) * pow(r_l, lf) * m; I(p, n) <+ flicker_noise(kf*pow(abs(i_r), af)/geo ,ef, "flicker"); end endmodule ///////////////////////////////////////////////////////////////////////
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 //////////////////////////XFAB MODEL ////////////////////////////// subckt rp1 (n1 n2 nb) parameters l=10e-6 w=10e-6 pm=-1 par1=1 + wcd_AR=0 + pmc=(max(1,1+int((w-8.000e-07)/8.000e-07))) + pmi=((pm>=0)?((pm==0)?1000:pm):pmc) + rsh=4.500e+01 + r0=(rsh*l/w) + tc1r=7.200e-04 + tc2r=5.500e-07 g100 (0 100) bsource i=(((v(n1,nb)+v(n2,nb))/2)/1.000e+03) r100 (0 100) resistor r=1.000e+03 tc1=0.000e+00 tc2=0.000e+00 isnoisy=no e101 (101 0) bsource v=(1.000e-04*v(100)*(1+0.000e+00/(0.000e+00+w))) r101 (101 0) resistor r=1.000e+03 isnoisy=no r11 (n1 n3) rctp1 m=pmi r12 (n3 n4) rsilp1 l=4.000e-07 w=w r13 (n4 na) rsbp1 l=1.000e-06 w=w r1 (na nc) rp1mod r=(r0*(1+v(101))/2) + l=(l/2) w=w r2 (nc nd) rp1mod r=(r0*(1+v(101))/2) + l=(l/2) w=w model rp1mod resistor + tc1=tc1r tc2=tc2r + af=1.965e+00 kf=3.682e-23 + fexp=8.823e-01 wdexp=1.000e+00 + ldexp=1.000e+00 r23 (nd n8) rsbp1 l=1.000e-06 w=w r22 (n8 n9) rsilp1 l=4.000e-07 w=w r21 (n9 n2) rctp1 m=pmi c1a (na nb) cp1suba w=w l=(l*(1-0.5*(1+tanh(l/200/w)))/2) c2a (nc nb) cp1suba w=w l=(l*(1+tanh(l/200/w))/2) c3a (nd nb) cp1suba w=w l=(l*(1-0.5*(1+tanh(l/200/w)))/2) c1p (na nb) cp1subp w=1e-9 l=(l*(1-0.5*(1+tanh(l/200/w)))/2) c2p (nc nb) cp1subp w=1e-9 l=(l*(1+tanh(l/200/w))/2) c3p (nd nb) cp1subp w=1e-9 l=(l*(1-0.5*(1+tanh(l/200/w)))/2) ends rp1 //////////////////////////////////////////////////////////////////////////////
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 ahdl_include "res.va" //res.va is on #15 rt1 (1 11) ppolyf_u_1k_t l=1u w=r_w trise=dtemp c1 (1 3) fox_sub l=r_l/2 w=r_w trise=dtemp // body rb (11 21) res_va + l=r_length + w=r_width + rsh0=r_rsh0 + dw=r_dw + dl=r_dl + vc1=r_vc1 + vc2=r_vc2 + tc1=r_tc1 + tc2=r_tc2 + tnom=r_tnom + dtemp=dtemp + af=1.878 + kf=8.68e-23 // terminal 2 rt2 (21 2) ppolyf_u_1k_t l=1u w=r_w trise=dtemp c2 (2 3) fox_sub l=r_l/2 w=r_w trise=dtemp //------------------- ends ppolyf_u_1k
Code dot - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 subckt rppo1rpo_dis ( n1 n2 body ) parameters lr=1u wr=1u factor=1 multi=1 mismatchflag=mismatchflag_disres + geo_fac=1 / sqrt(multi * lr * factor * wr * factor * 1e12) factmis=1.817689e-02 + * geo_fac * par_res_m * mismatchflag rsh=r_rppo1rpo_dis rendsh=2 * rend_rppo1rpo_dis ... ... ... rend1 ( n1 1 ) resistor r=max(min(rendo / 2 * (1 + 1 / (1 + jc1end_r * v(n1,1) * + v(n1,1))),rendo * 1.5),rendo / 2) r1 ( 1 2 ) resistor r=max(min(ro / 2 * (3 - 1 / (1 + jc1_r * v(1,2) * v(1,2))),ro + * 1.5),ro / 2) r2 ( 2 3 ) resistor r=max(min(ro / 2 * (3 - 1 / (1 + jc1_r * v(2,3) * v(2,3))),ro + * 1.5),ro / 2) r3 ( 3 4 ) resistor r=max(min(ro / 2 * (3 - 1 / (1 + jc1_r * v(3,4) * v(3,4))),ro + * 1.5),ro / 2) r4 ( 4 5 ) resistor r=max(min(ro / 2 * (3 - 1 / (1 + jc1_r * v(4,5) * v(4,5))),ro + * 1.5),ro / 2) rend2 ( 5 n2 ) resistor r=max(min(rendo / 2 * (1 + 1 / (1 + jc1end_r * v(5,n2) * + v(5,n2))),rendo * 1.5),rendo / 2) c1 ( body 1 ) capacitor c= multi*(Ca*((wr*factor+0.03u)*lr*factor/5.0)*1e12+2*Cf*lr*factor/5.0*1e6) +bv_max=100*0.9 c2 ( body 2 ) capacitor c= multi*(Ca*((wr*factor+0.03u)*lr*factor/5.0)*1e12+2*Cf*lr*factor/5.0*1e6) +bv_max=100*0.9 c3 ( body 3 ) capacitor c= multi*(Ca*((wr*factor+0.03u)*lr*factor/5.0)*1e12+2*Cf*lr*factor/5.0*1e6) +bv_max=100*0.9 c4 ( body 4 ) capacitor c= multi*(Ca*((wr*factor+0.03u)*lr*factor/5.0)*1e12+2*Cf*lr*factor/5.0*1e6) +bv_max=100*0.9 c5 ( body 5 ) capacitor c= multi*(Ca*((wr*factor+0.03u)*lr*factor/5.0)*1e12+2*Cf*lr*factor/5.0*1e6) +bv_max=100*0.9 c_soa ( n1 n2 ) capacitor c=1e-60 bv_max=j_max*wr*factor*(rend1_ov+r1_ov+r2_ov+r3_ov+r4_ov+rend2_ov) I_flicker_noise (n1 n2) res_flicker_noise //res_flicker_noise is on #15 + rmain=4*ro + m=multi + l=lr + w=wr + dw=0 + dl=0 + af=1.79 + kf=2.4E-23 ends rppo1rpo_dis
No.
There is no definition of res_va and ppolyf_u_1k_t.
And res_flicker_noise is not used anywhere.
Show me things correctly.
