Use Google, and type in relevant search strings, and you should find some companies. You could try first:
printed circuit boards finland producer
---or something in finnish, such as:
piirilevyjä prototyypit
....and then change some of the keywords as needed. With the above you will find several companies; I have checked that the search makes sense but not if those displayed shops are what you might want to find. (Btw. by using PCB as a keyword you get likely a lot of references to a nasty chemical substance, which is also known as "PCB", so better to spell the words fully out)
We use Top-Tec-PCB in England.
I know, England is not Finland but they ship through Europe.
I'm from Belgium, tried a lot of Belgian and Dutch manufacturers but changed to Top-Tec-PCB because they have good quality, fast standard delivery times, cheap extra cost for faster manufacturing of the boards and a good quality.
Contact them for a price request at t@top-tec-pcb.co.uk
