[req]interface dc voltage to pc
mastertushar
Member level 3
Mumbai, India
hi a want to interface small varying dc voltage to conputer by and port and i want to use it in visual basic to do further action .. my varying voltage say 0 to 5 v or 0 to 10v dc ,,.. can anybody help me for this using any microcon. like pic... thanx in advance
ama_trig said:
What you are looking for:
1)Dc Voltage Divider
2)PIC ADC
3)interfacing a PIC to PC
https://www.google.com/search?hl=en...q=ADC+to+PC+using+PIC+microcontroller&spell=1
thanx for helping i want the folling
how to use PIC ADC with source and ckt diagram( 1)PIC ADC)
2)interfacing a PIC to PC
the 1st link you given is right but its too old no links in that thread working... i want only single channel ..
and second link is also nice,, plz help further .. thanx again
    mastertushar
finally i got this project
but when i trying to compile the folling program to CCS C compiler it giving error
#include <16F876.h>
#DEVICE ADC=10
#fuses HS,NOWDT,NOPROTECT,NOLVP
#use delay(clock=20000000)
#use rs232 (baud=57600,rcv=PIN_C7, xmit=PIN_C6)
float value;
float temp;
float volt;
void main()
//Initialize and Configure ADC
setup_adc_ports( ALL_ANALOG );
setup_adc(ADC_CLOCK_INTERNAL );
set_adc_channel( 0 );
while(1)
//1 Sec Delay
delay_ms(1000);
//Read ADC Value
value = read_adc();
//Convert Value into Volts
volt = (value / 1023) * 5;
//Convert Volts into Temperature
temp = volt * 100;
//Send data to PC
printf(“Temperature: %.1f\n\r”,temp);
plz help
