Req:HV power supply design guide
goodboy_pl
Full Member level 5
Full Member level 5
dear friends,
i am going to design a HV power supply with following specs:
Vo=6000V
Io=1mA
load regulation=5%
Vi=12V
i am familiar with switching power supply design,but until now it is my first experience in HV power supplies.
i think flyback topology and UC384x is the best solution; my problem is about the transformer design and construction,also i think there is some problem in feedback circuit(resistor voltage devider),so i will be grateful if u could help me.
all of your comments,tips,app.notes and design guides will be appreciated.
thanx inadvance.
This PDF, i found in TI seminar online
**broken link removed** is about deisign of inductor and flyback, is a good review of subject.
an example
http://focus.ti.com/lit/ug/sluu096/sluu096.pdf
There are more interesting pdf in this link, you can see it changing the number, example **broken link removed**, betwen slup067 to slup129.
to generate high voltage i thiunk the normal flyback topology is not sufficeint as u will ned a huge number of winding in secondary
but as in TV horizentalor as in Spark ignition there's a good ways to generate those hiugh voltages
this way depends on resonance , wher the charged primary inductor in flyback transformer resonates with a capacitor between the collector and emitter of switching transistor those generating a peak voltage over primary windings which could be raised to the 6000 v with small turns ratiuo
i.e u can get about 1000 on primary by resonqance then step those 1000 to 6000 by 6:1 turns ratio
or u may connect the primary to the secondary at the collector so the primary current passes through higher inductance secondary generating higher voltage
this is my openion
also u should care about the isolation
also u may use voltage doubler
