Mithun_K_Das
Advanced Member level 3
- Joined
- Apr 24, 2010
- Messages
- 899
- Helped
- 24
- Reputation
- 48
- Reaction score
- 26
- Trophy points
- 1,318
- Location
- Dhaka, Bangladesh, Bangladesh
- Activity points
- 8,252
This is a very old fashioned industrial battery charger that uses 440V line converter into 220V DC via a resonant transformer. The problem is, the resonant transformer is not working and its saturated. Also they are not happy with it and don't want to use it any more.
So what I need to do is, making an alternative electronic circuit that can handle the load. Ratings are as follows:
Voltage: 300V AC.
Current: 0-10A.
Peak: 30A;1.5sec.
Run time: 24Hrs at 280V/5A.
Life time: must be over 2yrs
What I tried to do is making a TRIAC Based dummy AC load what can be connected in series with the line. Problem is the Amp is too high. I tried with BTA26, one pcs only. But when the load is connected circuit shuts down due to heavy load. And looses the control.
What I need to do is extending the current handling capacity of the TRIAC. But it is not wise to make parallel connection with TRIAC. So what is the way to control this heavy load in this voltage range?
Voltage: 300V AC.
Current: 0-10A.
Peak: 30A;1.5sec.
