dsctech
Newbie level 3
I am working on improving an old half bridge ATX power supply. Since most computers use mostly 12V, I want to upgrade the rectifier on the 12V rail. Right now it has a 20A Ultra fast recovery diode, with 200V peak repetitive reverse voltage. I want to add at least a 20A schottky, or maybe 30A (I have some lying around) mainly to increase the efficiency. It also has a spot on the PCB to add another rectifier in parallel, which I'm hoping would also increase the efficiency. My main question is, the schottky's don't have as high of peak reverse voltage ratings, and I'm wondering if using a schottky good for 45V or 60V would be good enough. I appreciate any help/insight.
I'm also going to replace all of the chinese electrolytics with high quality japanese lytics
