Editing and Deleting Your Posts
The administrators have decided to prevent users from deleting their own posts. In the past, deleting the first post of a thread would delete the entire thread, making it impossible for others to be able to read and learn from the information posted. There is also a limited amount of time in which you are allowed to edit your post, after that the post can’t be edited.
As a rule we do not remove or delete content from our forums so before you post consider this rule. If you don’t want to share a schematic or code then don’t post it but don’t expect to get help and then delete your post, users in the forum spend valuable time in order to reply in your post so this info should remain available for users that may have a similar question in the future.
