I want to normalize a signal and generate the power spectrum in matlab SP tool box. I used following command to normalize the signal.
=x1-mean(x1);
But, still there is very big DC components appears in the power spectrum. Can you please explain me how to eliminate this? Here I have attached a piece of my signal.
=x1-mean(x1); is by definition exactly removing the DC component. However, after applying a window or cutting out part of the data, you'll see a non-zero DCcomponent again. It can't be "very big", absolutely.
To be accurate, mean(x) is a low pass filter.
x-mean(x) is a high pass filter.
The problem of moving average is that you cannot get a very sharp
response. Look here for more detail.
If you want a good filter quite simple to implement, sharp, etc..., you may
consider a 2nd order IIR.
Dora.
=x1-mean(x1);
