summersnow
Newbie level 6
remote control using telephone
My project works like this.
Once the circuit detect a ring tone, it will off hook after 3 ringing tones(controlled by microcontroller).When the telephone is off hook, the speaker will play the message recorded in the speech IC.
The problem i face here is once i connect the whole circuit, the circuit cant off hook.I tried to change the resistor and the connection and it still cant works.
I wonder whether the problem is caused by the resistor at the transformer so i tried to change the value of the resistor.This is the result that i get when i make the changes.
1. When both of the transformer is connected with R1= 10kohm and R2=330ohm, the circuit off hook directly once the ringtone detected
2. When both of the transformer is connected with R1=10kohm and R2=10kohm, the circuit cant off hook when the microcontrolller send logic high to the base of the transistor.
3. When the part of the TR1 and the op-amp is not connected to the circuit, with R1=10kohm and R2=10kohm, the circuit cant off hook when the microcontrolller send logic high to the base of the transistor.
4. When the part of the TR1 and the op-amp is not connected to the circuit, with R1=10kohm and R2=330, the circuit is able to off hook when the microcontrolller send logic high to the base of the transistor.
The result 4 works but what i need is i need the opamp circuit to amplify the message recorded at my speech IC..My question is how can i combine the whole circuit to makes it off hook?
Please help me in this..Thanks in advance
