pardner
Newbie level 6
I have a requirement to have a double safe guarded system: user-manually and software-automatically enable/disable the system. Its easy enough to have a e-stop in series with the relay, but I would like the software to be able to disarm the e-stop button. If the software detects an out of tolerance event, I want to prevent the situation of having the user (or worse, a different user) sit down and re-run the system. Ideally, if the software detects an it of tolerance event it would shutdown the system and reset the e-stop, this way the user would have to manually re-enable the system before re-running.
Is the an e-stop button that has a remote de-energize circuit?
Thank you,
~Pard
Thank you,
~Pard
