can you explain Eb/No and its effect on the reliability and why we use this term , why not just signal to noise ratio?Bit error rate (BER), Signal to Noise Ratio (SNR) should pretty much cover that globally. Then there are the specifics like Eb/No, Symbol error rate, etc...at the channel level
Network Level: Packet loss, miss rate....
Essentially depends on your application and then you can decide on a suitable parameter. e.g. in cell phones you will use call drop rate
