Relay have coil, that coil is load for power supply, and is usually low. Can be from 30mA to 100mA and up, but not 1,25A, that is too high for relay coil, even for contactors.
1,25A is load of some consument which is switched with relay. This PSU can support this load without problem.
I don't know, because I don't know the power consumtion of the controlling circuit and the relay coils. If the current not higher then 0,75A it's OK with 2A else not.
