runtime
Newbie level 3
Relay design?
Hello All,
I have a small circuit in my car (it's a tracking device), it has a wire for main power (connected to main vehicle's battery) and also has a wire connected to a backup battery (small 12V 4aH battery).
Due to spikes or noise, the circuit sometimes stops working, I believe the oscilator stops working and the processor stops also, If I circle the power, everything works again, so I would like to have the circuit switched off/on when the starter is switched on, like the radio or lights goes off when you switch the starter on.
So the idea is to circle power to the circuit only when you start your vehicle...
is this possible with a couple of relays? or cut-out relays?
Thank you in advance
Peter
Hello All,
Peter
