ElecDesigner
Member level 5
Anyone know if smaller relays such as this one
suffer from contact bounce.
Got a problem where there appear to be burn marks and deposits on one of the contacts of a relay. The only significant current that can flow on the damaged contact is just after switch TO the damaged contact (i.e. it looks like it might be being damaged during a "make"). I just wonder if contact bounce would also cause a problem with arcing. I.E. if there is contact bounce, should we adhere to the "break" specs on make as the relay is actually making and breaking a few times before settling.
