Relay driver IC default output
seyyah
Advanced Member level 2
relay driver ic
Are there any ICs for driving relays? (Especially multiple relays)
relay driver
You can use ULN2003 or ULN2803
:wink:
uln2003 relay driver
IPS511 (high side) or IPS021 (low side) for larger relays
relay driver uln2003
There are a lot...
Try searching in www.ti.com (Texas Instruments site). They have free samples.
i2c relay driver
use open collector buffer like 74ls07 or 74ls06 i'm not sure
relay driver circuits
UDN2580 is a good choice. Eight channel, 120mA source drivers.
Allegro has also 32 channel driver ICs with serial port!!! You
can control 32 relays by using just 4-5 TTL signals from your
microprocessors. Check UDN5833 or UDN5832 but I don't
think you can find these chips on K.köy. Try Farnell :wink:
relay driver ics
Try the DP8311 , open collector
relay ic
I need relay driver schematics using ULN2003
please help me
Its Urgent
open collector relay driver
the circuit is as follows
drive relay ic
ULN2003 are god.
i have used it for driving relays...
relay coil driver ic
Hi
ULNs are best they are for relays having built in diode for reverse voltage protection. but there is limitation in the VCC voltage. if used with higher VCC voltages then it will heat up. so check for the proper IC
Added after 1 minutes:
From VCC i mean the power you will connect to relay. for smaller currents some times they work with no problems.
12 relay driver circuits
Hello,
I need to drive 32 NEC EA2 relays on my pcb but I want to use minimum number of driver ICs.
I was thinking about driving 4 relays from 1 output of ULN 2803 but from the datasheet I couldnt find out whether its possible or not..Besides I dont have any samples so I cant make any experiments.
Do you have suggestions for such a driver IC? Only requirement is to operate between -40 C to 85 C.
I need a response as soon as possible.
Thank you.
Re: 12 relay driver circuits
If you have a microcontroller or some kind of digital interface available, you can use TPL9202 made by TI. It can drive 8 relays with some fault protection as well (brown out condition)
Hello,
Thank you.
