Relationship between z-transform and DTFT
silverstar_28
Junior Member level 3
Hi bros,
any one knows the relation between z-transform and dtft?
thanks,
Re: z-transform and DTFT
The DTFT is a special case of the z-transform. The z-tranform is given by the sum
\[ X(z) = \sum_{n=-\infty}^{n=\infty} x[n] z^{-n}\]
If we evaluate the z-transform at \[z=e^{-j \omega}\], then we get the DTFT -- this evaluation is equivalent to evaluating the z-transform on the unit circle in the complex plane.
You can read more about this at Discrete-time Fourier transform - Wikipedia, the free encyclopedia
you can read more about this topics in Digital Signal Processing by Proakis
you can find more on this in signals and systems by oppenheim, willsky and in discrete-time signal processing by oppenheim schafer and buck.
In case of DTFT of a system function, it can do the transform only if the h[n] is a stable sequence Σh[n] should be less than infinite. So we can take DTFT only for stable systems. But by using z-transform we can transform even the unstable systems and can analysis the stability criterion.
ZT is more general clas of analysis of signals. For example DTFT of \[u[n]\] does not converge absolutely but ZT will converge absolutely.
thnx
purna!
Z transform is a more general case than DTFT. Practically Z Transform is used only to analyze whether a given system , filter etc is stable or not.
there is no such differnce between them....
z=exp-(jw)
z-transform:dtft :: laplace transform:fourier transform
In casse there are super exponential signals, one cannot find the Fourier Transform. In order to obtain a transform, not necessarily the spectrum, the signal is first "killed" by a super-super exponential and the transform taken.The advantage it offers is that a larger family of signals can be transformed.In the digital domain it is the DTFT and z-tranform, while in the analog domain it is the Fourier transform and the Laplace transform
You can read "Digital Signals Processing" by Jhon Proakis.
DTFT is nothing but the Z transform obtained on unit circle.so it is the special class of z transform.
silverstar_28 said:
Hi bros,
thanks,
z-transform is similar to dtft only when ω=1
