Regarding settng output delay in cadence RTL compiler
srini.pes
Member level 3
NIT calicut
dc::set_output_delay -clock [find / -clock clk] 0.9 [find / -port OGH2/GH20/DQ10/x_reg[0]/D]
here my clock name is clk and the interested out put port is "OGH2/GH20/DQ10/x_reg[0]/D"..
it showing some error in syntax is it correct or not.........
please guide me
It would be useful if you included the exact error message.
However, I suggest that you try the find command alone first, so you make sure they are not returning null string.
Hope this would help.
~sakr
Respected sakr,
First of all thanking you for responding to me
rc:/> dc::set_output_delay -clock [find / -clock clk] -fall 3000 -port [find / -port {OGH2/GH20/DQ9/x_reg[0]/D}]
Error : A required object parameter could not be found. [TUI-61] [parse_options]
: An object of type 'port|pin|port_bus' named '-port' could not be found.
i have mentioned like above as shown
am getting this error...i think there may be an error in the scripting it self can u suggest me the correct scripting or any thing to overcome these problems
waiting for u r reply
thanking you
you just need to remove "-port" from the command
following the syntax of set_output_delay from RC documentation
there is no identifier before the port name.
Hope it works now.
~sakr
