MPU6050's Accelerometer and Temperature interfacing with atmega128
Hi all,
@Easyrider83
Here i have tried to interface MPU6050 with Atmega128, I have write code for Accelerometer and Temperature sensor. In which somewhat i satisfied with Accelerometer readings but i confused about temperature readings..
Kindly see the code and result, and correct me that why temperature readings constantly increase after approx 50-60 readings? Its start from actual room temperature like 36..37..38... up to 80 and then it came back to 36(notice it from o/p readings).
I am confuse that wheather I getting right result or wrong. Because i think it may also possible that MPU6050's die temperature may constantly increased. So please look the code and result and correct me.
Sorry, I'm too busy this week and next one. As I remember, I didn't worked with internal temperature sensor of MPU6050. So, I can't help you this moment. Sorry)
This device is measuring room temperature or chip's die temperature??
Generally it should be measure room temperature but as per its reading/result i think its a die temperature.
