Feb 20, 2012 #1 P pavanhs Junior Member level 2 Joined Jul 5, 2011 Messages 24 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,409 Hi, What is the difference between Fault and a Defect ? Thanks in Advance, Pavankumar HS
Feb 20, 2012 #2 N nisshith Member level 3 Joined Feb 15, 2012 Messages 61 Helped 11 Reputation 22 Reaction score 10 Trophy points 1,288 Location Hyderabad, India Activity points 1,607 Defects refer to physical malfunction errors like Short-circuited Source/Drain, PG shorts, open interconnects etc. Faults are modeling defects as logical/timing failures like STUCK at 0/1 fault or STUCK OPEN fault.
Feb 22, 2012 #3 P pavanhs Junior Member level 2 Joined Jul 5, 2011 Messages 24 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,409 Hi nisshith, So what is the difference b/n STUCK at 0/1 or STUCK OPEN fault. -- Thanks Pavan HS
Feb 22, 2012 #4 N nisshith Member level 3 Joined Feb 15, 2012 Messages 61 Helped 11 Reputation 22 Reaction score 10 Trophy points 1,288 Location Hyderabad, India Activity points 1,607 Stuck AT means ur port has either got connected to VDD or GND and STUCK Open means there is break in wire
Feb 22, 2012 #5 P pavanhs Junior Member level 2 Joined Jul 5, 2011 Messages 24 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,409 Thanks for the quick reply, But Stuck AT also we do for nodes(wires) whether they are connected to VDD or GND rite??
Feb 22, 2012 #6 N nisshith Member level 3 Joined Feb 15, 2012 Messages 61 Helped 11 Reputation 22 Reaction score 10 Trophy points 1,288 Location Hyderabad, India Activity points 1,607 Yes, why would we check STUCK AT those are supposed to be connected to VDD/VSS. We do check for all nodes which by mistake got connected to VDD/VSS
Feb 22, 2012 #7 P pavanhs Junior Member level 2 Joined Jul 5, 2011 Messages 24 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,409 Can u please briefly elaborate me the difference between Stuck at and Stuck Open?? Basically im not getting the difference b/n wire and node(port). stuck-at--->port(or)node(or)wires ? stuck-open--->wire ?
Feb 22, 2012 #8 N nisshith Member level 3 Joined Feb 15, 2012 Messages 61 Helped 11 Reputation 22 Reaction score 10 Trophy points 1,288 Location Hyderabad, India Activity points 1,607 Stuck AT --> NODE (point where multiple nets/pins are connected) tied to VDD/VSS STUCK OPEN --> breaks in WIRE
