AOQ
Dear all :
as the attachment shown, the reference voltage generator ( for Pipelined ADC
testing PC Board) is implemented by two resistors, two capacitors, and two unit
gain buffer.
My questions are as follows:
1. What's the purpose to add two 10Kohm resistors in series in the positive input
node of OPamp ? since there is no current flow into such branch ?
2. why add a 10uF capacitor between positive and negative input node ?
I think maybe it is used to bypass high frequency noise, but I dont know how
3. Should I need to add bypass capacitors network (10uF, 1uF, 0.1uF) after
the reference voltage generator output ( Vref+ and Vref- ) ?
I am afraid that such large capacitive load will cause the OPamp to oscillate ...
If i add a inductor (100uH) between the reference generator output and
bypass network, will it help ?
4. About the unit gain buffer, sometimes i see someone not to connect Opamp
output to negative input node directly, but to add a resistor ( maybe 5kohm)
between Vout and Vin- , why ? @@
Thanks for any response .
Best Regards
gain buffer.
Best Regards
