Reduction of welding noise
yurble_vn
Newbie level 5
Dear all,
I'm going to build a small controller work in welding environment, and the trouble is the noise in this environment.
Is there anyone has experience in the welding noise reducing ? Any suggestion is welcome too
Thanks,
noelm
Newbie level 1
welding noise
I use a RFI filter in the input sheld all control wires coming from and to your controller and make sure you ground your controller box if it is metal.
IanP
Advanced Member level 5
West Coast
3 phase mains filter for welding
In addition, consider fitting a good single-phase/3-phase mains filter on the welder power input and, this is a must, put your controller on a metal (steel) enclosure and connect "good" earth to almost everything you can ..
Regards,
IanP
yurble_vn
Newbie level 5
electrical noise from welder
I don't get it. A little more special please
many thanks
IanP
West Coast
welding noise level
Here is what I meant:
If you have 3-phase welder you will need 3-phase filter, if you have 1-phase welder you will need 1-phase filter, and the most effective option is a 2-stage mains filter .. see picture below ..
Regards,
IanP
creative_35
Full Member level 1
Under Mango Tree
Re: Welding noise
I don't know what micro you are using. I have some experience with electrical noise. I did an Industrial washingmachine controller before two years. It had some noise problem while switching inductive loads. I used PICMICRO16F84A. I tried somany filters like snubber network to load and to the control relay coil also. but the result was a big failure. used a CPU powersupply(hope it was filtered) but it increased the noise level. finally I accidently read the internal noise filter portion in the datasheet of 16F628. and I recompiled the code for F628. the result was amazing. I removed all the filters and used normal power supply. it was working perfectly. conclution: 16F84 is not suitable for noisy enviornments. use F628 instead.
