orwikcons
Newbie level 2
Greetings!
I have a problem in my car with the speed giver. It gives larger speed than I drive. So I would like to put something to correct the problem. It sends a mass frequently, so when the transmission makes one revolution, one half of revolution the mass is sent through the signal, and the other half the signal is empty, sa as the car moves, the signal is frequently rotation of mass/empty. I hope that I gave a conceivable explanation...
I need a device which will make the frequency reduced for a rational coefficient (not integer), about 1.123. Input signal is the frequency from giver, and output signal is a frequencu multiplied for a coefficiente. Can it be made?
