kumagai
Junior Member level 1
I'm going to design a rectifier for low power input at 2.45 GHz.
How low is the limit for input level? The lower, the better.
Now I'm referring to the attached pdf. If I use many diodes, can I get high output voltage?
My desired voltage is around 0.5 V.
If I can get that voltage from the rectifier, it can be boosted with TPS61220.
